Hello members.
I have some problem with my Beosound 3200 CD spindle motor. When a CD inserted then pressed play the CD start spinning but not at normal speed and strange rattling sounds coming out of it, like something stuck under the hub or inside the motor. When I tried to turn the spindle by hand there is some kind of resistance and turning unevenly with a grinding noise. There is no vertical or horizontal play on the motor, feels normal but something is definitely wrong there. I like to remove the motor for checking it but the screws hide under the spindle hub . Please help me to find a way to safely remove the centering hub. The mechanism is VAU 1255/21LF and I can't find any information how to dismantle/remove the spindle motor.
Thanks in advance.
