BeoRemote One BT
You'd probably have to take it to someone, who has one of the Android based BV's and connect it to this in bluetooth mode.
But you'd gain nothing, I guess - since you will continue to use it in ir-mode with the V1 afterwards.
The newest version should be 2.7.24
How do you check the software version on the BT remote?
