BeoRemote One BT
Hello
Does anyone know if there is a way to upgrade the sofware of a BEO remote BT? I looked around on the internet but couldn't find much.
Where can I find info about recent software updates, if any.
Regards
Jan
It will be updated once the TV got updates.
So everything will go through the TV? Will you, as an owner be able to decide whether or not you want to do this?
Do you know if there have already been such updates in the past?
Regards
Jan
This is my version, I wonder if it is the latest?
The latest version of software for the tv is V0.2.1.22
Just check your TV if it has the same version.
The latest and current software version is 2.7.16 so you are up to date..
The BeoRemote One BT software will be updated automatically via the Bluetooth connection from the TV.
The update starts when the TV is switched to standby.
You will be able to see the update progress in the display of the BeoRemote One BT when it happens.
After the installation of new software, the BeoRemote One BT will reboot for 30 seconds and then will show the Bang & Olufsen logo.
If you have other BeoRemote One BT remotes then you need to switch the TV on and then off with that additional remote for it to be updated as well.
Keith
Very clear info! Thanks for the feedback
Jan
Regards Keith....
Keith
I managed to go into the service screen. It says version 2.7.9. So probably not the latest version. Can I update the software myself? I have a V1 so update over BT won't work.
Jan
Nice... Thanks Keith
