It may not be the BT version I guess?
Though, it does have BT mentioning in menu ...
Beoremote One and Beosound Core?
It seems you're using the original BeoRemote One - this has only the IR function and does not allow a Bluetooth connectivity.
The Bluetooth source that is appearing on your remote seems as though you have "product integrated" a Network Link Multiroom product to maybe a BeoVision - allowing you to play the Bluetooth source from your Multiroom through the BeoVision.
You would need to get an updated version of your BeoRemote One to get the "pairing" functionality - the new BeoRemote One BT does include IR communications, so you would be able to use it with dual functionality.
Hope this helps.
Thanks,
Vish
I have/had the same problem.
As soon as I changed something in the "link to other products" menu the tune-in list etc came back. I just changed one "link to other products" pressed "verbinden" (connect) and the menu was back. I guess it is a minor bug ?
Nico
Hi Razlaw,
How hard is it to switch between IR and BT mode. It sounds like you're doing this just fine, but I thought I read somewhere that you had to switch between BT and IR mode... can this be done just by creating IR and BT products in the remote list, or is there more to it.
I'm thinking about getting a BeoRemote to control a BV8 and Essence mk2... and I don't feel like screwing up the BR I have programmed for my Eclipse (at least until I get some basic questions answered like this one).
Thanks,
Stan
Thanks Razlaw. This is very helpful. Not ideal, but not too bad either. I think there's another Beoremote in my future.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
