Does anyone know if the BR1 is able to control basic functions (next, previous, on/off, volume) of the BS Core?
Yes you can do all basic functions and even more. For ex. all sources from the Beosound Core will be synced to Beoremote One. I'm struggling for the moment to add LIGHT commands which can be rerouted to Beolink Gateway.
Also see this thread:
Glad to hear this. Have ordered a BeoRemote One for use with my Core.Yes you can do all basic functions and even more. For ex. all sources from the Beosound Core will be synced to Beoremote One. I'm struggling for the moment to add LIGHT commands which can be rerouted to Beolink Gateway.
Some updates. I'm now running Beoremote One together with Apple TV. I think some one in B&O have made a REALLY good job because both Apple TV - MENU -> BeoRemote One HOUSE/MENU and Apple TV - TV -> Beoremote ON INFO-button works flawless!
What I did after that is Bluetooth paired the Apple TV with Beosound Core and every things works perfect controlling volume and of course LG Sampling (HDMI-CEC) is enabled on the TV which will let the AppleTV turn on / turn off the TV.
The only thing missing now, is the lack of sending LIGHT commands to the Beosound Core but I can live with talking to SIRI instead.
Received my BR1 today. Very happy with it. Seems to work perfectly with the Core including displaying the Tune in stations. Also works well in ir mode with my older equipment, other than one problem I have posted in a separate question thread.
How did you pair the two - I am struggling to make my BR1 and core work together? How do I do it?
Been looking at the other threads here, and in the manual...YouTube etc etc.
Help?
D
I think using the BR One BT is a great way of controlling the multiroom speakers as you can have an interface of what you will be able to play without having to go to a mobile device.
Firstly, what you'll need to do is go onto the B&O app, select your BeoSound Core> go into product settings> configure and then it'll take you into the internal settings of the Core - under remote controls you can open your BS Core for pairing and then go into your BeoRemote One BT, press LIST, go down into settings> pairing> pair> "open for pairing" - once both are open for pairing they will connect and all functionality will work very similarly to when being used with a television.
All sources available on your BS Core will be seen under the "Music" button.
Vish
Vish
Thank you Vish!
The core part was all good. No problemo, but my beoremote does not have a ‘pairing’ option in List>Settings. Is it a different (perhaps outdated) version of BR1 I got my hands on? It looks like this (ie. I think its the first version):
It may not be the BT version I guess?
Though, it does have BT mentioning in menu ...
