BEOPORT can not register and connect ( as consequence) to Net Radio
Thanks very much for the .reg file.
In case the link went broken, the content of the file is:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Bang & Olufsen\BeoPlayer\N.Radio]
"ViewSelection"=hex:00,01,02,03,04
"BufferTime"=dword:00000005
"ServerURL"="http://nradio.beoplayer.com/nradiodata.asp"
"UserId"="60B1D8994C224AC69B91931AE710521A"
"SoundIcons"=dword:00000001
"EnableDebug"=dword:00000000
To creat that file, open a Text Editor (Editor in Windows or Notepad++), copy the lines into it, save the file as N.Radio.reg , you may use the command line to insert it into the registry, but it's easier to right-click the .reg file, open with: Regestry editor.
Hi everybody
does N.Radio still work to you ?
I didn't use N.RADIO for long time because it was easier to access through the home to digital radios with DTV+red button from Beo4., accessing my BV55.
But in order to listen them from my PC with Beoport, I added the registry values just now.
But N.RADIO doesn't see any station.
I have W10 Pro ver. 1903
Any hints ?
