BeoMaster/Sound Net Music
Can someone please explain how I get N Music to show on the Besound display.
I have transferred Cd's  to the BeoMaster, I can play the CD's from the music library, but  N Music is not shown on the display. What is shown on ther right hand side of the Beosound displa\y is;
CD
N Radio
A Aux
Settings
I have tried A AUx for net Music but it is not that option.
Any help would be most appreciated.
Thank you
Where is "N.Music" not displayed, on the Beosound 5 display?
Did you set the Beosound 5 to "Audiomaster = Yes"? Then it reacts to "CD" = "N.Music". This changes if you set the unit to "Audiomaster = NO".
If you copied a large amount of CDs to the system it is quite busy (as it is relatively slow). Leave it alone for a few hours (or over night) and then you should power it completely(!) off by holding the power switch on the back of the Beomaster 5 for a few seconds (green status light changes to red on the backside of the Beomaster 5). Wait a moment and power it on again. If you see messages which operating to select: Ignore it. The unit boots up automatically into the right option.
