Hi, i just got a Beomaster 2400 (to go with my beogram 4002) and im not really sure how to hook up speakers to those inputs. are B&O speakers only compatible?
Thanks.
Thanks.
You can connect ANY passive speakers but you will need 2 pin DIN speaker plugs to connect to your beomaster which are available form any decent electrical retailer such as link in the UK.
Thanks Chris.
its hard to tell from the pic, but how do my speakers (i guess speaker wires) connect to that 2 pin DIN plug?
Some do, but most often it's just another female DIN socket at the speaker end, or clip/screw posts like in any speaker. Some old small B&O speakers had fixed cords, but it's possible someone has already snapped the plugs off to connect them to a non-B&O ampifier at some stage.
Don't make this too complicated - anyone with at least one eye, two hands and some common sense can connect the screw-type DIN plugs π
-mika
To secure the cables I have in the past but a blob of silicon sealer in the sleeve. You probably cannot use the connector again after should you need to change the cable length though. Although most cables are made up and then left for years as they are so not really a problem.
Craigπ
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
