I have a Beomaster 1900 (Beomaster 1900-2 T2903), a friend gave me it with a pair of Beovox 2400. I would like to use it daily but there was a annoying "hum" at good volume. So I decided to change all the capacitors.
I bought the kit from beoparts-shop.com with all the caps needed.
Great, after a long time awaiting them, I finally found time to change all the 62 caps I found !
I made a quick test without all the panels and screws -> every tactile buttons worked (the phono was not working before, now it is), but no sound. I plugged an headset and then, I could only hear the radio when I pushed the volume to maximum. I though it could be a mass wire problem, so I put all the panels and screws.
Now I have a new problem: instantly after selecting a source, it goes to standby...
I check every caps polarity, sounds good, checked some wires, no one seems unsoldered.
More info: A service have already been made one time before I acquired it, all the 2.2uf have already been changed, but I replaced them. Also there is a strange part with long wires not in place (I guess it have been added by the person who serviced it long time ago). And I did not replaced the reservoir capacitor, not in the kit.
https://photos.app.goo.gl/s4bJZUPTtPaPRRSZ8
https://photos.app.goo.gl/jfNeEw4ZyrmM6zXy9
Could please help me find some things to test ? I only have a multimeter, no capacitor tester
Thx :)
