I've picked up a beomaster 900K which has a few issues, the main one being the tuner being inoperative on all bands. The unit powers up fine and power supply voltages all seem good, other issues being that it sounds very "bassy" unless turned to a minimum. Phono and tape inputs work if a little "hissy" unless the tape input is set high.
The archive forum of this site suggests faulty AF116 transistors as a common fault for the tuner so I'll be taking a closer look at these in the next few days. The reason of posting is to ask if there is a recap kit available anywhere to save me identifying all the electrolytics and then ordering probably a lot more than I'll need.
