yachadm wrote:
Check those carbon resistors which are in the Power supply circuit, especially those whose function is to drop voltage - you'll probably find a couple out of spec.
Did you do a voltage check across the power cap, as before?
I'd be interested to see the difference in measurement results.
Well, in fact they all seem to be just a bit above the supposed values, or close enough, so nothing to report really.
As for the power cap, no real change in values, i just noticed that depending on the input voltage it's more or less close to specs (normal, i suppose). So at 220V it's 34,5V, and at 240V it's 32V. Given that 34V is aimed at, i guess that operating it at 220V it is, then.
Dillen wrote:
Worth checking the 1,5Kohm resistor that sits right next to the cap with the severed pin on the stereo decoder.
It looks chipped but may still be OK.
It measures 1.55K, so seems ok as well. Looks like these dinosaurs of resistors do resist to time too.
So far, after the recapping and a few measures at same points around the power supply, things seem just a tad more balanced. I managed to adjust to a spot where i get around 24V/34V where needed, but the same problem than before remains at below voltages. This is to say that i have 34,6V on the power cap, it goes to 24V & 24,2V after the 2N555, from there it goes to the AC128 (24,2V / 24,4V / 34,6V), and it's after that, at AC126 that it goes a bit weird, and i don't know what it means ; i get 24,4V / 8,6V / 8,7V where i should have 24,4V / 9V / 9,4V ?
To the same effect, the amp board gets exactly 24V at arrival, but for example at the first input transistors i measure 7,9V / 8V / 16,5V where it should be 6,8V / 6,9V / 18,5V. And so it goes, everything below 24V is a little off.
Any idea what is to be looked for ?
[EDIT] I also get a somewhat high "bzzzzz" from the transformer which was already there from the beginning, but maybe just a bit louder now. [/EDIT]
Sebastian
