The next chapter ;
i thought to report on how it went, so that maybe one day it can help someone else, in any way, as my good Karma payback.
So, got the recap kit (thanks Martin !), nicely documented, and attacked the job.
Luckily this is old circuitry we're talking about, because my soldering equipment isn't what you would call the most advanced kind (nor in the best condition, to top it all). But it went well. Well, i'd say so, and i won't show you any too-close-up photos so that you could tell me the contrary 😂
Turns out that this was indeed a version of the 900K that was still partly undocumented in Martin's information vault (just how unlikely is that ?!). So photos were taken. Notes were written. PM's exchanged. And here's a résumé of all that. A recapping of a Beomaster 900K, subversion S 290, export model with a six input voltages selector, and whose wooden cabinet has a stamped date of 8 JAN 1965.
This is an extremely image-heavy post, so my apologies to those who it might derange, but personally i would have loved to find one like it when i first encountered my radio, so here goes. The first few photos are for identification, of the untouched unit before the recapping. You'll notice (well, i just did) that the volume and radio dial buttons are reversed (the volume button has the black point) for the moment, during the project. It goes pretty much in the following order ; the original unit, the recap kit, and then the recapped unit.
Front
link
Back
link
Power unit ; 1 cap to change
link
Tuner ; 1 cap to change
link
Bottom side ; in my model version there are 12 caps to change (+ the two 800uF output caps that are fixed to the back wall)
link
Top side (on topmost there are the amp board on the left, and the stereo decoder on the right)
link
Amp board top ; in my model version there are 17 caps to change
link
Stereo decoder top ; in my model version there are 6 caps to change
link
Stereo decoder bottom
link
The recap kit from Martin
link
Bottom after recapping
link
Amp board after recapping
link
Power unit after recapping
link
Here are all the original caps from the main board, with their respective designations on the schematics that i have. After discussion with Martin, i've come to learn that these designations may well vary between model versions and/or schematics, so it just might not be the same ones for you. But this is the complete set on my specific model/version.
link
And here's the same thing for my amp board, to be considered with the same grain of salt.
link
And here's something i discovered only while taking the photos, even though i had manipulated the board frequently during days before (i've bent the cap slightly to make a point, i hadn't noticed it at all before). A severed + leg on a cap on the stereo decoder board. Just for the curiosity factor. It'll be fixed by the recapping of the stereo decoder board, coming in the next chapter.
link
So there, for now. What remains is the recapping of the stereo decoder, and the single one on top of the tuner box, both to be done in the coming days. I've also completely redone the wooden cabinet and given new luster on the gray speaker grilles with some polishing. It's starting to look good ![Beer]()
Sebastian
