Beomaster 900K & a novice needing help
Yeah, i hear you, Mika. I was kind of submerged into getting it work, and while testing in short periods, the charming faults sort of jumped at my face. I've actually spent the day playing my iPod through it, and the hissing is nowhere to be heard on acceptable levels. So i've already written it off as part of my machine and have stopped worrying about it. Your three (wow, nice) ones seem to confirm this. As i've had absolutely no experience with the model i have no idea what is to be expected and what is not, and as i would of course want so much to get the best out of it, it's easy to get carried away. But, so, yeah, the hiss was there at extreme volume and no music, but it's not supposed to be played like that, now is it.
The same goes of course for the "muddy" sound, maybe it's supposed to be like that. But... i don't know, somehow i wouldn't think so. To some extent i expected it, the lovable "vintage warmth". But, it's not the warmth that comes through, it's just... how to put this ? It's kind of... flat, and muddy. The bass, when augmented, is boomy and just breaks into a wall of overall mud (i'm overstating to describe it, it's not as catastrophic as that really). I get pretty good clarity when lowering the bass to zero, but then it's of course just tinny. I've no idea if it could be the bass & treble section that is at cause actually, or the amp section.
I really wouldn't wish to sound like a whiner about it, it's a beautiful, beautiful machine. And i have no desire to overdo it. I wouldn't even want a modern sound out of it. Just... the best of it within my abilities.
Of course i wouldn't even be at this point without you guys, so kudos to you all, your welcome and help for a complete newbie was amazing. Not at once were your comments destined to make me feel stupid (though i did feel stupid and still do), even though this thread took it's length and i was pretty much lost all through it 😂 So, yeah, really, thanks.
It's up and playing, and that was the main goal, and for that i'm a truly happy camper.
Sebastian
I just saw this post now, and I hate to see my friends blowing good fuses for no reason!
I have a homemade solution, which is indispensable on my workbench. Basically, it's an in-line AC power-cable extension, but with a 100W lamp in series with the live AC line. Cut into the Live AC conductor (not the Neutral), and connect the lamp to the 2 exposed wires.
If there is no problem in the radio (or whatever), the lamp remains extinguished, and the radio plays fine.
If there is a problem in the radio, causing a short, the lamp illuminates, and the fuse doesn't blow. The bad component will heat up. After about half a minute of leaving the current flowing, I can identify the bad component quickly, by just feeling around on the PCB.
I always work with this on all devices under repair, and through a 24-hour burn test. That bright 100W lamp gets my attention pretty quickly, when it illuminates. Only after the repaired device has operated for 24 hours without illuminating the lamp, do I connect the device directly to a regular AC mains socket.
There are 2 slight disadvantages:
1. Do not expect to get full AC voltage at the output side of the power transformer in the radio - if the service manual specifies say 40VAC, you'll see about 36VAC. This is normal and with the DC voltage stabilization at the Bridge, you should have normal DC voltage after the regulator.
2. Some devices with high-draw Switch-Mode Power Supplies cannot start, and will simply pulse - this is not relevant to our vintage B&O radios.
It's real easy to build, and I hope it helps you.
Menahem
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
Thanks for the tip Menahem, this sure could have come handy (and surely still will) as i must've blown 10+ fuses while trying to find the fault. I'm sure to build one in the days to come.
Sebastian
What Menahem suggests will be fine as a safety precaution for yourself and
your house supply installation, mains fuses and some circuits inside the radio.
However, a 230V 100W bulb will easily draw a current higher than 250mA so would most
likely not have saved any fuses in this case of a shorted transformer secondary
(depending on the transformer load factor etc.).
A smaller bulb maybe, 60W or so, but again that would decrease the supplied
current to a working set considerably.
A variac would be the best thing but the acquiring of such a device is
not always easily justified and a package or two of 250mA fuses aren't
that bad an alternative.
You did well.
The BM900 will never be completely "noise-free". There will almost always be
a slight hum or static if you listen for it.
Try connecting a pair of larger speakers and you'll be very surprised when you
hear what this set can do.
It's just a couple of watts each channel but what a sound.
I have experimented with a 60W, 100W, and a 250W lamp.
If you increase the radio's volume during non-faulty operation, at some point the lamp will start to flicker, and interrupt power to the radio. This is normal. A higher value lamp will delay the onset of this phenomenon.
However, the objective of the lamp is not to test the radio at full power, only to determine and isolate system shorts, which will be identified, irrespective of the radio's volume setting.
You can certainly use a 60W lamp for everyday purposes, and increase the wattage if you have higher power units under test - I use a 250W when testing Switch Mode Power Supplies to delay the onset of pulsing.
Once you've experimented with a couple of lamp wattages, and you're familiar with the power requirements of your radios or whatever, you can select (and change) the correct lamp value with confidence.
The higher lamp values will certainly prevent fuses blowing, even in the case of a transformer failure - I've had that case occur also in SMPS's.
Of course a variac would be an ideal solution, but at this point, I don't have one, and this is a very useful substitute.
Menahem
Just to report something strange, and maybe you specialists could explain it to me ; it has now been 3+ days that i've listened to the unit daily for lengthy periods (it plays practically all day), and the sound has significantly changed. I'm positive that it's not (only) my imagination. It has gone from dull and dark to something much more balanced and quite pleasing actually. Sure it's not exactly perfect (as to my expectations), but had i heard this when i fired it up the first time, i probably wouldn't have spoken about the "muddy" sound at all. The treble and bass feel so much more "separated" and defined than in the beginning that it's like another unit to my ears.
This is now especially evident on external speakers, even though well heard through the internals as well. I tried external speakers just as well in the beginning but that didn't change anything on the quality, now it's really pretty pleasant and laid back. Ok, so it's still somewhat "veiled" and there's the hiss and hum, but really, it's rather nice.
I think i've read about the caps drying up and "jamming" before taking up the service again, is this that ? Could it be that after a prolonged period of downtime it just needed some time to "heat up" ? Or have i really just lost my mind and autosuggested myself into a true believer in the lack of better action ? Or is it yet something else ?
Whatever it is, it sounds better and better 🤒
But please, do enlighten me if you are in the know.
Sebastian
It's well known that caps take time to break-in. I'm pretty sure that that's what's happened to yours, although I would not be too happy about that. On a radio that old, I would not be playing it at all, unless I had done a complete recap.
These old caps cannot be expected to be within specifications, and may (I say "may") be overstressing some particular semiconductors, which may be unobtainable.
Having established that the radio now is apparently "faultless", I would set about doing a recap now, and then relax in the knowledge that it would be good for at least 10-20 years thereafter.
Also the heat of the renewed operation may stress some soldered joints, which may break, causing possibly catastrophic failure. While you do the recap, you will automatically resolder many joints, and you can keep a look out for any other cracked joints.
Menahem
I was aware of the phenomenon with new caps, but i haven't changed any on this. Except for 4 transistors, a zener and a whole bunch of fuses come and gone, it's all old gold.
Interestingly, your take on recapping differs somewhat from that of Martin's who doesn't seem to consider it quite as urgent as that (or maybe that was while the BM was still in need of repair). I'm looking at the service manual and listing the caps, largely for interest and getting myself familiarized, and will probably get to it one of these coming days. If any of you have any generic info, tips and/or recommendations on recapping, do tell 🤒
And yet another uneducated question ; i have measured around some voltages on the board (power & FM on, volume at zero), and they are quite off from those indicated on the schematics, any idea on what might be causing this, or if the measures should be taken under specific conditions that were not mine, or yet if all this is normal ? Example ; i measure 31.8V out of the rectifier where it should be 34V, or 8V on the amp board where it should be 6.8V etc.
Sebastian
You can regard these as "new" caps - after not having been used for many years, the caps are reacting to the change in their composition with electricity flowing through them again.
Condition/lifetime of old caps is sometimes related to how the radio was used - if in a hot evironment, the caps would dry out, if in a damp environment, the leads would corrode, etc.
Not to be rude, I trust no radio owner with an old radio, and assume the worst - I have had some real basket-cases (radios, not their owners) in for repair, and I have found that the best investment in my time and the owner's long-term enjoyment, is to do a complete replacement of all electrolytics. Many of these old radios still have the original bees-wax capacitors, the wax having dried out decades ago.
Never touch the mica or polyester caps, unless proven faulty - they were specifically put there for circuit stability - and replacement is generally expensive, and realignment time-consuming.
That rectifier voltage is a perfect clue of bad electrolytics - the big coupling capacitor is not doing its job, and probably has excessive ripple - do you have a scope to check it?
Also, you can probably safely double the size (say 470uF --> 1000uF) of that new capacitor - in the old days, those capacitors were very expensive. Larger caps have better ripple capability. I use Nichicon HE and PW for these types of circuits. Yes, there is a performance difference between different models of capacitors.
I'm sure that there aren't a lot of caps to replace - I've done a few tube radios, and their capacitor count is much lower than a transistor radio. It would be really worth it to use the correct caps.
If you put a list with close-up pics of the caps on the forum, I'd be happy to help you with selection.
Menahem
If it runs fine, I wouldn't worry too much about the slightly high voltage unless
caused by ripple as Menahem suggests.
Try putting your multimeter in AC-volts mode and measure across the large
filter capacitor and let us know the result. Not the best way to measure ripple but it will
give us an idea of the ripple level.
There's an adjustment for the 24V supply on the main board, did
you measure/adjust this after repairing the power supply ?
You have a PM, check your inbox at the extreme top right corner of this webpage.
