Hi, it's me again. So, i didn't turn into an amazing technician overnight, but i did learn some stuff by reading and measuring. I've gone through a few components, verifying their correct state, and thus eliminating possible causes, but find myself again at my wit's end. And so was hoping that maybe you could enlighten me.
Here's a quick summary : the 900K blows one of the 250mA fuses each time it's turned on. It can be one or the other.
The parts i've verified and truly believe to be OK ;
- the four AD139 output transistors
- the SP1446 + resistor
- the 1000 uF power cap
- the two 800 uF output caps
- the cap 514 (80 uF)
- the resistors (0,39) 546, 547, 643, 644
- the rectifier
So i desoldered the leads from the power cap positive, and when the rectifier is connected, the fuse blows. But i tested it and believe it to be ok. So i moved to the next in line, and that is the 9.1V Zener diode (912 on schematics). And here i'd need some guidance ; i measured it both ways with diode test and ohm meter, on board and desoldered, and it gave 0 every which way each time. But i saw some discussions elsewhere that stated that Zener diodes need to be tested in circuit with load and what-not. Would you confirm this, or do the tests in my case suffice to conclude that it's dead ? Also, would a dead Zener seem like a plausible cause to my problem ?
[EDIT] Oh, and should it be dead, i couldn't find its wattage on the schematics, on the web i saw 400MW is that correct ? [/EDIT]
Sebastian
