Beomaster 900 rg de luxe
My vintage setup is complete! I finally found a pair of cubes! They are in neat condition, no scratches on the feet, but they could use some refurbishing. All the drivers are functioning.
The sound quality improved dramatically. Furthermore the sound stage has widened.
Icons of their time
Great, now you should search for the Beolab/Master 5000 classic. ..
Yes, and after you have found them you'll think, "Now I need the bigger Beovoxes"... and another pair of Cubes...
You gotta feed the virus  😜
Well, I was thinking about some combination of my third cube tweeter connected to a center speaker via a stereo connector box. I'll definitely keep you updated. For now the setup perfectly fits my needs 😁
My beomaster found himself a brother
Nice find, and a lovely match!
Does it all work?
Can you tell me how you removed the dry oil and lubricated your Motor? I am a beginner and any help would be great.
Thank you
Just a note to anyone new or new-ish to refurbishing any vintage item from someone who scrapes a living from it
It might seem either obvious or superfluous but the time and heartache you will save by being totally anal over putting each type of screw/component in a separate little plastic cup (of the disposable type) or zip close bag and labeling it (write on a bit of masking tape and stick to bag).
Photograph every stage of the disassembly no matter HOW simple and obvious it looks at the time.
And finally the one that separates the pro's from the armatures - cut card panels and masking tape them in place to protect wood veneers / perspex panels etc and do all your re-finishing of wood / perspex etc when it is separated from the electronics and use a thick wool blanket to rest the item on on your workbench to protect it.
Always use the same side "UP" for the blanket and buy the best quality masking tape you can from an auto refinishing supplies.
Buy good quality small steel, brass and nylon "Wire Brushes" - they are the most useful things after the screwdriver!
