I've been cleaning the cabinet today, and took away 50 years/2kg of dust. The next step is teak oil. While cleaning the cabinet I took out the beomaster (which gives no sign of life at all) and the beogram (which turns VERY slow at 78rpm only).
The beomaster:
No signs of life... Checked the fuses, both okay. When plugged into the mains, the transformer gives a hum. When selecting any source, the Radikator moves from 5 to +/- 1 and moves back when pressing off. Where should I start? I couldn't find any lights inside the cabinet, see picture below. I'll need two of those, I have the service manual so finding them will be the biggest problem I think...
Login to view image
The Beogram:
Needs a new needle since the current one is broken. Turning VERY slow when 78 rpm is selected, but speeding up after a while. I checked the belt which definitely needs to be replaced as it broke of 2 places when I touched it. Furthermore I think the motor needs cleaning so I took it out. Is it possible to open up the motor from the bottom and clean it or should the whole mechanism at the top be disassembled to gain acces to the motor? At last, does the beogram need a recap? I wasn't able to measure anything yet but it seems to me like a good idea to me due to the age.
The cabinet:
I took out the glass wool used as dampening material for the speaker cabinets and will replace this by some more modern, healthier material. The pneumatic spring of the left door isn't always working, it probably needs some adjustment and cleaning.
