Hi all,
I noticed that on my Beomaster 8000, when you are on the PHONO input (no record playing), you can hear FM transmissions leaking through and at max volume you can hear loud white noise and the FM transmissions are obviously louder. On the other inputs (TP1 etc) it's pretty much dead quiet. Only on PHONO do you get this added noise leaking in. I have had someone else test their 8000 and they have confirmed that theirs does this also.
Is this a common issue? Any way of re-engineering this/improve on the design to eliminate this?
Its quite annoying, especially listening to quiet passages on vinyl at loud volume levels and hearing the news being broadcast in the background!! I pull the aerial out of the Beomaster, but the internal receiver is so good, I still get FM reception with no aerial even attached!!
Any help?
