Hi to all technical specialists.
After a complete refurbish of a BM 8000 incl. new LED's for the Displays I can clearly see that the lower display for Balance is reacting parallel to the upper display for volume.
Just only a little bit but even in a bright day visible.
I' ve checked the displays twice, all LED's are in the right direction and the masks have no chrome coating which could make some short circurits.
Already changed all LED related resistors to a higher value and the LED driver IC's are exchanged too.
The lower display is still visible but all LED's are dimmed as expected.
All other displays work as expected.
I've already refurbished 3 of these Beomasters and used always the same type of LED's without any problem
My suggestion would be the PHASE 1, 2 and 3 transistors or the LOGIC 1,2 and 3 transistors.
Maybe I'm on the wrong way and someone has had the same problem, like a comment on Beolovers website shows, regarding the display refurbish.
Look here down in the comments:
https://beolover.blogspot.com/2012/05/beomaster-8000-display-brightness.html
Any advice is welcome.
Stay tuned, Kind regards Christian
