Have you reconnected it since then? If so, does the display still shows random digits? Was it in use when the power outage occurred?
First of all, take the following advice with a grain of salt: my experience with that complicated machine and in electronic is limited. But so far it's been a success...If unsure, don't touch anything and find someone competent, willing and interested. Avoid those who would say it's good for the bin.
If it still shows random digits when connected, I would probably check if the 5v supply to the microcomputer is still there. If the value is below that, it's normal that the microcomputer goes into a locked position in which it shows a random display when the BM is plugged to the main.
So you should have, on standby, 5V at pin 2 and 3 of P48, on the power supply board. If you don't have this 5V, then I would investigate around why not. (regulator right under cap C35, attached on the heat sink on the right side, the C35 caps itself). Perhaps the machine just need a complete recap, especially on the power supply board.
Guillaume
