Hi
I'm new to Beoworld and in need of help with my Beosystem 7000. I've owned this for about 12 months without issue.
At xmas I wanted to play a vinyl present and when I switched it on everything lit up but when it the record played there was no sound. I checked the speaker wires in the back of the amp, they were in and when wiggled sound returned, albeit for only an hour or two. I later removed the top of the amp to see if anything was obviously wrong, which there wasn't. But not being to techy did not delve further. There are two switches that were moving when powered up. I also noticed there is a fan that is not working.
My question is this, is this a common fault or an easy fix? Or has this got to visit an expert? Is there an expert near to me, I live in Leicester?
Also can the rubber bands for the Beocord still be acquired?
Thanks Phil
