Hello everyone,
My BM6500 has developed an issue with its tuner. A while ago I replaced old caps in audio signal path, power supply, CPU board and front PCB (to improve two-way ir communication). Unit works really well, I was astonished by its sound quality to be honest... Remote range has improved greatly. The only problem that has developed since recapping the BM is a strange issue with its tuner.
When recalling memorised stations by pressing a number on a remote directly everything works fine, but using 'step < >' buttons, or 'program step' button on the front panel causes some king of audible discharge. Then the station tunes correctly and everything works ok.
I haven't been using it a lot since i thought it has been misaligned or something, because it required really strong signal and even when using external powered antenna the reception was bad. Opposed to my BM7000 which easily locks on correct frequency just with simple 0,5 m of wire attached as antenna. A friend of mine told me not to touch anything on the tuner board, as replacing electrolytic caps may totally misalign the tuner. I decided not to listen to him and replaced all caps on the tuner board, also, I desoldered a wire connecting the tuner board with the antenna socket.
Sound quality has improved A LOT, as FM reception did. Now BM6500 locks to a frequency (with stereo) just as easily as my BM7000, but the strange issue with irritating discharge remains...
Could anybody possibly tell me how to fix this, please?
I recorded a video showing mentioned issue. In the beginning I recall memorised station directly with numbers, later on, I use Step < > buttons.
[View:http://www.youtube.com/watch?v=Bs79wrTPmrE:800:0]
Thanks in advance!
Filip
