The winter is finally letting go (the snow level has dropped below 0.5 meters, anyway) and I'm again getting interested in actually doing something with electronics.
The first project of the year will be a slight overhaul of my Beomaster 6500, one of my earliest B&O buys from 2007. Back then, I only adjusted the idle current of the power amps, but now it is time to do a bit more.
I spend probably 99% of my time listening to radio, and the tuner has developed a couple of annoyances; first, the antenna socket apparently has a bad contact, and lately one of the stations I listen to most has developed a bad distortion while others are fine. It is at the lowest end of the frequency scale, so this might be some real problem.
I'll also replace some caps in the power supply and the CPU board - the IR control range has gotten worse lately, which is usually a sign of them starting to go bad.
Finally, I'll rewire the transformer to 240V instead of the original 220V so the Beomaster doesn't warm up so much as it does with the current nominal 230V mains voltage.
So, the Ebenholz panther will have to go and step around somewhere else for a while...
