Beomaster 6500 - entering FM frequency
I understand to tune the radio using BL1000 you press GOTO+enter 4 digits for the FM band like 1000 for 100.0 MHz+STORE, then preset station number and STORE again
But how do I enter a three digit frequency like 95.5 MHz? Pressing 995 does not work, same with 0995 or 9950. So how this is done correctly?
hI LEV1945,
I've got exackly the same problem with my BEOmaster 7000. Did youz ever find out how?
kindly regards
 Martin,
yes , that's how it works🙂
thanks again!
Jojoe
And what about the station mumber
, how you store the frequency under a specific station number?
Press Go To, then number of channel and Store, AFAIR.
jojoe wrote:
complete sequence:
You first enter the frequency xxxx ( Go To xxxx without comma ), when found: (STORE  station number STORE )
does anybody know how ,if possible,  to display the selected radio frequency on a Beomaster 7000/6500 ?
Not possible. Only visible on the MCP.
