Hi.
There is propably a simple fix, but I haven't been able to find any help in this forum.
Problem: Beomaster 6000 (type 225x), volume v and ^ works. Preset volume using slider goes all the way up when not in zero. (either 12V or -12V across motor unless at zero). Preset value 0 works, value 10, 20, 30, 40, 50, 60 goes all the way to 60 and motor keeps turning (12V on motor).
I have tried the following: All transistors on pcb 6 is OK. Recapped pcb6, resoldered all connectors. Recapped pcb 3, tested volume pot (3R4) 100K ok. Changed pots 6R25, 6R24 and 6R32.
Supply voltage to pcb6 is ok. IC3 is ok.
Preset voltages (measured on cathode 6D8) are all ok (1V to 15V)
Have not changed 6IC5.
When trying to calibrate volume control:
1. volume step 0: Not possible since volume goes all the way up when pressing preset 30. In position 0 voltage on motor is 0V
2. preset volume 0: OK, when preset pot low, voltage across motor (5TP20 and 5TP21) is 0V
3. v ^¨ volume speed: OK, 6,5V across motor when buttons are pressed
What am I missing?
Regards Thomas.
