I'm Chris and I'm new to this forum.
I have already restored a Beomaster 1200 and a Beomaster 3000-2, but I need help with my Beomaster 6000.
I completely swapped all of the capacitors. Two of the indicator Lights (Volume Control) 2x 3,6V and 100 Ohm Resistor for each LED at Anode.
The old trimmers are still original and will still be replaced. The values of the trimmers on the circuit board 9, however, are correct.
The IC's of the circuit board 9 would have to be replaced because they make crackling noises while listening to music but the Heatsink is not hot. Thats my fist problem with this Beomaster IC's: 9IC102 / 202 / 103 / 203 are BDV65A and 9IC104 / 204 / 105 / 205 are BDV64A.
My next Problem is the Power Supply. The Heatsink gets very hot and the Voltages are not correct.
I read in another forum that I have to swap the transistor and IC's 16TR2 / 16IC1 / 16IC2. I noticed that under two resistors the board is black. So I think that these resistors 16R1 and 16R12 are burned.
Now my Questions:
1. Did I replace the lamps with the LEDs correctly or does that lead to the malfunction in the power supply?
2. Can I replace the IC's BDV65A and BDV64B with BDV65B and BDV64B?
3. Would you recommend me to replace the transistors and IC's 16TR2 / 16IC1 / 16IC2 in the power supply?
4. The resistors 16R1 and 16R12 are normal 47 ohm 1/2W right?
I'll try to attach photos tomorrow morning. Many Thanks.
Chris
