I am in the process of refurbishing a BM6000...
Amongst other things (such as 7-seg displays etc), I have recapped the Power Supply PCB, remembering to link the two pins of 'C1', and also the Power Amp PCB along with fitting new trimmers for quiescent current and output offset voltage...
Rather than risk overheating of the Power Amps, I decided to run up with a Bench Power Supply +/- 50V DC.
I have found that the 'no load current' on the left hand amplifier immediately jumps to 21mV at power on, but cannot be adjusted with R234. The left hand output sits at around -45V.
The 'no load current' on the right hand amplifier climbs to 22mV, and is adjustable with R134, but the output sits at around -10V.
I have checked all diodes and transistors with my PEAK tester, and they all show good...
In desperation, I have now tried a second Power Amp PCB from another BM6000, and very strangely, it behaves in an identical way...
I have double checked the power connections on P34 (1 = -50v, 2 & 3 = 0v, and 4 = +50v). I am pretty confident that there is no need to connect anything to connector P31 & 32 at this stage (although input will be muted)...
I can only think that all the semiconductors need replacement, on both PCBs... Would seem unlikely...
Does anyone have any suggestions... Am I doing something wrong ?
Tony
