Beomaster 6000 (2253) start-up problem
Hi
Regarding to the servicemaual Page 6-6 maybe you try to look for the "TIMEBASE" of IC 4 PIN 15. Should be 664 Hz.
On TR 10 I think you can't measure anything because the Probe of an oszilloscpe will draw down the Cristal frequency.
A good place to start would be Collector of TR 11.
The Timebase is generated from the Crystal X1 goes via TR10 and TR 11 to IC 6 PIN 1.
Comes out as a divided signal on IC 6 PIN 6 = 15,5 kHz.
Goes to IC9 PIN 14 comes out divided on IC 9 PIN 12 = 7,75 kHz
Goes to IC 7 PIN 14 comes out divided on IC 7 PIN 11 = 664 Hz
Goes to IC 4 PIN 15 "TIMEBASE"
I'm not completely sure but I think this Timebase is used to get the buttons working with a strobe signal.
Without this you won't be able to swich on or off or anything else.
Let us know if you got any progress!
Kind regards
Christian
