Dear Beo Specialists,
Unless I am mistaken, I did not find a thread concerning the following problem:
Beomaster 5500: while playing the left or right channel can go soft at once (not both at once). This usually goes away by either moving swinging the volume down and up or by muting and un-muting or by turning unit off and on.
Sometimes the unit will be with one channel soft once turned on and some cycling with the volume will fix the issue. Sometimes one channel goes soft and comes back again by itself. This can typically happen a few times in an hour. Otherwise all works fine and sounds fine.
What are the best first steps to fix this problem? As far as I know (I do not own it from the beginning), it is all in stock condition.
Thanks in advance
