Good day fellow Beofans
I purchased a Beomaster 5500 that didn't work through right channel. The history of this amplifier is a repair and overhaul after it blew up its right channel power transistors. After 2 years of faithful service it blew again on right channel.
I took the gamble that the new problem would be simple and bought it. In fact, it blew again the right channel power transistors. I noted that the previous repair placed bridges to connect transistors, as board damaged in these areas. The 0,22 ohm resistors were also replaced.. I placed new Philips BDV 64B and -65B and the rest seemed all right. In moving the BM around I heard some noise from under the other board where the input/output are. After slight removal I found a pretty big screw. I imagined it getting under the section of relay and shorting right channel, but pure speculation.
After power up I measured and found right channel sticking to positive rail voltage. I opened again and found R220 reading low and ID201 and TR206 suspect. I removed TR206 (BC547B) and it is bad. I also noted that it is different and already replaced in previous repair. Now R220 and ID201 read good. Other components in neighborhood seem OK. I will order new TR206.
Since I am not so good in this, is there something else to look out for?
Thanks for your reading time
