Beomaster 5000 Loudness Indicator
Hi Everyone,
Sorry to keep asking questions but you guys seem to know everything when it comes to B&O :)
I've recently noticed that the loudness light has a very slight glow even when the loudness mode is off.
Loudness functions properly and the light is as bright as ever when its switched on, but as I say when off its still lit although very very dimly... It may have been like this as long as I've had it and I've only just noticed its that dull.
Is this normal? If not is there anything I could look at?
Thank you all once again,
Lee
Any Ideas anybody? :)
Can anybody with a beomaster 5000 confirm that this is normal behaviour?
Sorry to nag but I'm desperate to get this system working correctly.
Lee
I'll have a look when I get home tonight.
OK, I've had a look - I'll preface what I saw by saying that I've had mine for approaching 30 years and never noticed!!
When in the off or standby mode there is nothing, when there is a source selected, in the "Loudness" off mode then the letters "LOUDN" are very slightly illuminated red. As you say, this does not interfere with the function and I've never noticed it until you said so.
(Now I'm paranoid)!!!😮
I'm sure it's OK!😁
Mine is exactly the same as that, its only when a source is selected that you see a slight glow...
I wonder if they are all like this?
Rest assured - I've owned mine from new, nearly 30 years, and I've never noticed a deterioration!
Checked my BM 6500.  When it's off it's off.
It doesn't seem to affect anything but I'm a sucker for things being 'just right'
I had a PM with Dillen (Martin) and he thinks it could be a bad cap or a transistor out of spec.
But if 2x BM5000 are doing the same thing then maybe they are all like this..
Like I said its very dull, and you really have to look to see it, but its definitely got a dim glow.
The BM5000 and BM65000 are two very different beasts, but thanks for your input MediaBobNY
