BeoMaster 5 start failure
1st have a look here
Hi
have you tried reboot from recovery? You must plug a old fashion keyboard to the USB on the masterunit, then you can select the reboot with up and down / enter.
With my limited understanding of PC functioning, I would say that if you see the invitation for recovery - it is already the part of Windows booting process. Since you get there - most probably BIOS and POST functions of the motherboard work fine. At least CPU, Memory, HDD and the VideoCard as well as USB since you are able to use keyboard.
My bet is that it is corruption of the main Windows or BM-recovery partition of the HDD.
That's an interesting hypothesis, but how to test it? It would be so much easier with the BeoMaster 5 ServiceTool!
I recall now that I had the similar case after relocation of the unit, when BS5 went into the black screen after the initial boot invitation. After minute or so the red LED started to send SOS signals. That happened again and again after reboot. I was thinking of worst, but the reason was only loose connection in one of the cables.
The explanation is that BS5 do not see all of the connected accessories, cannot load the driver and stops booting.
So, it will not be useless anyway to take a look on all the connectors between head and the master unit, clean and check if they are inserted firmly. Who knows, it may help.
Thanks for the advice. In my case, BS5 is fine. The problem is BM5 unfortunately.
