Hi All.
Since I found out how easy it is to install a new harddrive if you have the service tool, I have tried a few discs I had laying around over the weekend.
I tried some 2.5" Toshiba 128gb 5400rpm discs, a Hitachi 5400rpm 250gb, and a Kingston SSDNow 240gb SSD disc.
All the discs I tried worked fine, however the BM5 with SSD disc was much slower in copying 10gb music from network to it, than the rotating discs. Also the MOTS rebuild was for ever in building on the SSD.
The UI was smooth, and the looooong list of radio stations also seemed faster. But It was not a huge difference over the original HDD.
Since the original disc is making noises I dont like, I will be changing the HDD, but I cannot seem to find the MX100 anymore, however I found the MX500, and since I will not be doing any cloning of the discs, I am thinking about giving it a chance.
I am a bit worried though about the slow transfer and MOTS rebuild I experienced with the Kingston SSD.
Anyone has any ideas on why this is a problem, and are you guys experiencing the same with your SSD's ?
I am actually thinking about just putting a new 2.5" 1TB 7200 disc in to ignore the fact that XP embedded does not support SSD that well.
/Weebyx
