I have two partial Beosystem 4500s that I purchased used in the early 2000s. I have never had a good place to set them up, and didn't have speakers for them, so they have been stored away in boxes for quite a while. Recently I bought a mint pair of Beovox RL 60.2s, and decided to finally hook them up. Unfortunately, one of the Beomaster 4500s (the minty one) no longer powers up. The other one works fine, but has older firmware and some blemishes.
The one that isn't powering up makes 2 clicks when it is first plugged in, but there is no standby light on the control panel, and operating a Beogram 4500 connected to it won't cause it to 'wake' and switch modes. I was able to open it based on a PDF of the service manual, and didn't see any visual clues (4 fuses looked fine, no discoloration underneath any components that I could see).
I would love to get this Beomaster running again but don't know where to take it to get looked at (I am in Seattle). There is a very highly rated audio technician here that I will bring it to, and I'll bring the PDF of the service manual. But I'm not sure if there is anything foreign about B&O to a person that has never worked on it before, or if it's all the same if you've got the documentation.
One other thing -- when I removed the touch panel I noticed the glass was starting to separate from the frame, so I might try to reattach it first since I'd hate to bring it to a repair shop and have an accident with the most often broken, hardest to replace part on the whole thing!
Has anyone else had an issue like this, and have people had success with non-B&O specific repair options?
Thanks!
