Hi there,
I have a BeoMaster 4400 which recently stopped working. I've noticed the Fault Relay activates when I turn the unit on and I am getting no sound to either speaker because of this. I have a bit of electronics knowledge, however not enough to be able to diagnose and fix this issue.
From browsing these forums in the past, I turned to replacing a few of the Output Transistors. I replaced OIC 200/201/202 and 203. I found that when I did this I would get a small amount of sounding coming from the speakers when I turned the unit off.
Since then, I have taken it to a Hi-Fi repair place which told me the OutPut Transistors needed to be replaced, however, when they replaced these transistors, one of them was blowing so they gave me the unit back unfixed and I feel like they might have done something else without admitting so.
Since then, I have tried replacing the Output Transistors they left out of the BeoMaster 4400 when they gave it back to me. OIC 201/202 and 203 were missing. I replaced these only to find that OIC 202 will blow straight away when I turn the unit on. I'm replacing these with the required TIP141/146.
Could it possibly be that one of the MPSA54 transistors is defective? I have read about these doing so online.
Please help, I would love to get this amazing unit working again, and it will make more than me happy!
Thank-you
