Greetings from Oregon: I recently acquired a Beomaster 4400 receiver along with a Beogram 4004 turntable. Both pieces were non-operational when I brought them home, but after some refurbishing and repair, they are both working great. I have a question about the 4400 receiver. Of the eight transistors, the four transistors (two TIP146 and two TIP141) mounted on the right side of the rear panel seem to get quite hot. Is this a normal condition? The other four transistors are only slightly warm. It doesn't seem to affect performance at all, and I can run the 4400 for hours without any issues. I haven't replace any of the ROE electrolytic caps (I count 10 total). will replacing the 10 caps cure heat issue?
Thanks in advance for any help or advise.
Kevin
Eugene, Oregon USA
