Hi all,
New to the forum, looks great!
I have a mint looking Beomaster 4400 that I'm slowly bringing back to life. The previous owner had hacked in another DIN cable (probably to connect it to an external equaliser). In the process of using it, it seems he has blown up the pre-drivers. I already fixed this by removing his hack, and replacing those transistors (5TR112 - 5TR212).
Now the only problem is FM reception. I get white noise. And that's about it...
What I already checked:
-Supply voltage is good (15V) -> even on a scope, no oscillation/ripple to be seen.
-2TR1 looks OK (diode check base to emitter/collector 0,7V in both cases)
-Moving the dial left and right, moves the tuning voltage up and down - I see that at 1R1/1R5
-1TR2; I don't know, measured it with the diode check: 0,9V/1,0V. So it measures like it should, although pretty high. Is this normal for a BF255? Don't have ant spares around.
Anyone can give me some pointers? I have some experience with amps, but FM isn't up my alley yet ;)
