I recently purchased a Beomaster 3400. Some pics are below with the exact model number, etc.
So far I' yet to have much luck firing it up.
Here's what has happened and what I've noted, maybe some clues to the problem lie here:
• The unit is connected to the mains using a travel adaptor (this will be my starting point of investigation...).
• When I first powered it on, the radio tuning light was functioning (just the one lamp that indicates the active frequency..
• No other lights lit up.
• After fiddling around with various buttons, the radio lights ceased to work. Unfortunately I can't pinpoint the moment this happened.
• I am in the US, I switched the voltage to 110v on the base of the amp.
• I do not have a speaker set attached.
• There is a very low freq. hum audible when the unit is on. It appears to be getting power, but nothing is lighting up.
• There is a low frequency humming (very faint) in my headphones when turned on. This hum increases as you turn up the volume on the amp.
• I played a record with my Beogram 4002 connected to the stereo input. With the volume turned up to 9 or 10 on the amp, it is possible to hear the record play very softly.
• The back of the unit got slightly warm after I was fiddling around like this for about 20 minutes.
So, given the above, can anyone recommend a place to start looking to diagnose and repair the problem?
Many thanks.
H
