Hi Everyone,
so I purchased a BM 3400 - I saw it on a local auction site for a reasonable amount of money and it took less than a minute to make a decision...
It has just arrived, I plugged it in for 10 minutes or so - it works in general - I tried FM and phono output, the balance, front/rear, volume etc. but I already can tell that it needs work. The things I was able to see myself are:
1. It seems very dusty inside, also the potentiometers do not move smoothly (I assume they should, ideally)
2. The cooling fins at the back near the speaker connections got extremely hot, beyond the point of touching - I turned it off as soon as I saw this
3. Should the "Off" button stay depressed after pressing it? That is the case here, it seems that the answer is no -- but I'd prefer to hear from the experts
4. The line driving the FM unit broke after trying it out for a few minutes
5. The "On" light comes on, so does the "2-channel power" one, but the others don't seem to work
6. The large faceplate does is not aligned properly - I will try to attach some pictures to show the issue.
7. I tried to open it - after taking out the screws the top was stuck, I was only able to delicately make approx. 2cm opening, and the front wood panel with part of the top plate detached- seems like the glue in the corners holding the wood panels together dried out (?) I was able to put things back together though.
8. there might be more...
Are these issues fixable in a relatively easy way? Or will it need a more serious overhaul? Can anyone suggest how serious are these issues? I am not good with electronics myself, so I will have to give it to a technician. However in my area there does not seem to be one specializing in B&O, just a few "vintage audio" places and it would be extremely helpful to have some advice beforehand.
Also, should there be a service manual inside the receiver?
I'd like to have this unit a my main receiver in the living room (my wife agreed!) so I'd like it to look and function well after the repairs.
Any advice will be greatly appreciated!
