I'm recapping my beomaster 3300 but I have a problem with the two filter caps I hope you guys can help me with.
The caps aren't marked well, but my assumption was that the darker side was the negative. This would mean however that the connection is red wire to negative, positive to negative, and then blue to positive the other cap.
I would normally assume red would go to positive, but it could be that I'm mistaken or that I'm mistaken in the polarity on the original caps.
Any of you know the correct way to connect them?
Also a suggestion on replacement caps would be good. I have two regular 105c Vishay caps, but should I try find something better?
