Dear Beoworld fellows,
this is my first login and post after more than 10 years - the stuff has been working greatly up until recently when my Beomaster 2400 developed a fault.
All touch commands work function without problems and all lamps are working except the treble one but the fault appeared independently. Namely, one morning I turned it on only to discover that there was no sound coming out. After thorough checkup, I discovered that muting transistors 2TR206 and 2TR207 are switched on (cca. -9V on G) as soon as the unit is powered. Backtracing this fault brought me to 2IC6 where pin 13 is permanently on -12V and I suppose this triggers the muting. All components from there are healthy: 5TR7, IL10, as well as components on PCB3.
Other useful info:
- all supply voltages are within specs
- muting transistors 2TR306/307 are not shorted to the ground
- output stage is healthy
I hope everyone is doing well and fine here at Beoworld and I am thanking you in advance for your kind advice on how to repair the 2400.
Best regards,
Milan
