Beomaster 2200
Hi, I have one of these along with a beogram 1902 and some S45.2 speakers, and it makes a lovely sound. however, having no user guides with it, and never having seen one before, I was just wondering what the P1, P2, P3, P4 and P5 buttons do. I assume they link to the  5 dials which raise out above them ,but what do they control, and how are they used? As if i press one of the buttons, it raises the phono buttons and kills the sound.
CT
They are the preset radio channels. When you press the dials , they come up and there is a geared wheel that when turned allows you to change the frequencies. These are actually the best pre-set design from this era as being geared they allow very fine tuning. To select the programme, press the button on the front panel.
Oh I seeee. Nice touch there. now I just need an aerial πŸ™‚
Is the cover for the connections in place? If not I have one knocking around somewhere.
CraigπŸ™‚
