I'm new here and look forward to all your advice and wisdom.
I have a Beomaster 2000 that I love and has been great for many many years of which I believe I am only the second owner, I inherited it from my sister because the speaker foam surrounds were rotten on the CX-100's. I bought the M75's to use instead and only recently had the foams on the CX-100 redone.
1-in one of the CX-100's, the upper 4"woofer (mid range i think) has a buzzy scratchy sound noticeable on quieter music. wondering if the coil wasn't centered when the foams were glued on or if its just bad and needs replacement. I'm willing to remove the dust caps to have a look see but i dont really know for what to look.
2-the tuner has never worked well, maybe tuning in a station or two clearly, but i live in a metropolitan area so it shouldn't have that hard of a time. even with a bi-pole antenna wire attached, no better. I believe i read somewhere that tuners can be adjusted or calibrated? If so I'm curious how to do that.
3-Of late the right channel has started to distort on both A & B speaker outputs. I know its not the speaker because the test speaker sounds fine on the left channels. Can anyone give me an idea of what needs fixing? I can't afford to take it into B&O service, they want $200 just to assess it and then who knows how much for parts. Although I'd hate to ruin the pure B&O integrity of it, I hate to just see it sit there and collect dust. I'm a pretty capable DIY(albeit pretty green when it comes to electronics), and am willing to source high end replacement components on my own if needed as I understand they can be quite affordable from the source. Or maybe someone here has replacement parts for sale?
4-nowhere on the beomaster 2000 does it list ohm minimums for speaker output. Does anyone know what these values are? I feel this may have led to my right channel failing as i have had multiple pairs of speakers hooked up (in parallel i think) thru a speaker switcher box
I'm willing to upgrade to silver membership, to get service manuals and access to classifieds, but for now just getting my feet wet and looking for guidance.
thank you in advance everyone
