Hi
i just got myself a beomaster 1900 thats in perfect cosmetic condition and all the bulbs are working however it does seem to have a couple of issues and I am wondering if anyone can tell me where to start diagnosing them.
the phono channel has a humming noise which I believe may be the capacitors? Also the sound seems a little flat and I am not sure both channels sound the same.
the tuner also seems very weak; I used to use an old beosystem with no antenna and had no issues; this will only faintly pick up channels
any advice would be appreciated and if it needs any capacitors or whatever changing does anyone know if Dillen does a kit for these?
regards
martyn
