Beomaster 1900 Misschien weet Blackrix raad.
De afstemming op FM1 doet het wel?
The circuit for the source indicator lamps works closely together with the muting circuit, allowing for a
brief muting of the sound while switching source.
Wrong wattage front panel lamps can leak enough current through the circuit to activate the muting.
Check that the lamps are correct.
If some sources work and other don't, you can confirm the diagnosis by swapping the lamps from one that works and one that doesn't.
I can supply correct lamps, if you need.
Lampjes kan een oorzaak zijn, heb je die vervangen?
Hi Martin, I have some lights from my previous order.
The lamps will light up normally - also if they are wrong wattage.
The problem is with the circuit they work in.
If you have some spare lamps from me, try fitting them for the sources that are silent.
