Beomaster 1900 -2 Beomaster 2400-2 Volume diagram
Hi  All
I was wondering  if any body had the volume control drawing for the  -2 model as this  has 3 ics not one as the 1900  /2400 has  ?  it dose not appear in the 1900-2  service infomation ??   any help would be great
 or where it may be found .....
Regards Ron
(Thread moved to the Private Wanted section).
The new volume control is mentioned somewhere, either in the B&O Tech notes or in the Bomark pages.
I will look for it.
OK, found it.
That was easy 😂
B&O Tech note BM19-24-2
Drop me an email and I'll send you something.
Thanks Martin
Thanks for the fast  help
That will make life easier
Regards Ron
