Hi guys,
All of a sudden I noticed that the output of my Beomaster 1900 sounded distorted. I traced the problem back to the tape input, higher frequency sounds are fine but the lower frequencies are distorted. Radio and phono input are playing perfectly.
Sadly I do not really have a clue on where to look for the failure. Is there a specific component in the tape input circuitry that I could check? I did some soldering before on this beomaster so I hope I can fix it myself with some help from the forum.
Best regards,
Bart
