Beomaster 1700 Type 1701 crackling
Thanks Martin.  Do you or anyone else know of a suitable alternative or material for replacing the worn rubber clutch 'plates' ? (i was thinking of cutting up an old bicycle tyre inner tube, but suspect it may be too thick !).  Thoughts anyone ?
Hey Tim, does the switch for your AFC switch stay engaged when you press it, or is it meant to be momentary? Mine is a different colour to the rest (Blue cap instead of red) and it doesn't stay in when you push it. Not sure if that's normal or not
I reproduced them some years ago.
PM or email me.
The button itself doesn't stay down (it would look bad with a button not sitting flush).
It merely moves the switch inside that triggers the AFC (and the AFC light) on and off for each pressing.
Sorry, yes the internal switch is what I meant. Mine doesn't engage, suspect the switch is broken
- Or the whole assy needs adjusting closer to eachother.
In severe cases it's necessary to glue in a small plastic sheet or similar to shoten the distance between the switchs plate and the buttons black actuator arm.
Do you mean like this?
http://imgur.com/a/24EQjot
Someone else had already done this, bit the problem seems to be in the switch mechanism itself, Ie. Even pushing the grey switch, it doesn't click in, it just pops back out again
An update
I cleaned out the left hand side potentiometers with some Servisol Clean and Lube NA-1012. I couldn't find anyone who sold the suggested brand in New Zealand. Outcome, they move easier and I got some very dirty cotton buds, but no change to the popping. . (side note, the resistor was missing from the Bass line. The LED doesn't work either (Unsurprisingly). Do you think its safe to just put a new resistor on and hopefully get it to work or is there a way to test the light? I assume it was removed for a reason).
 I just finished replacing all the capacitors in the Tone section and the Power amp section. When I repowered it the popping started up again. I then played with it a bit (Not really sure what I did, I slid the balance pot up and down because  I was noticing that the left speaker was crackling even when the audio was panned all the way right).
It seems to have come right after around 10 minutes of messing with it. Has been playing for around 30 minutes with no crackles, so Great!? (although I'm not entirely sure what actually did it)
Two of the power supply caps are on back order so I haven't tackled that yet. I also haven't touched the radio side at all yet. I ordered new caps for that so I guess I may as well change them out?
Meget tak for din hjaelp Dillen
