Beomaster 1700 Type 1701 crackling
I have just bought a secondhand beomaster 1700 (the one with the big belts)
it seems to work alright and then after an hour or so it starts crackling. (Well, the speakers start crackling)
Then stop again etc. very intermittent. its not when I'm adjusting anything. It does it whether I'm listening to the radio or via DAC plugged into the Tape input, so I suspect its something in the preamp or power amp sections
Any ideas on what might cause this behavior?
Aging capacitors would be my first guess.
Is it in both channels?
Yeah it's in both channels. But I don't think it's in stereo if that makes sense, i.e. both channels crackle, but making different crackling sounds
Clean potentiometers, replace electrolytic capacitors.
Thanks Martin. I must admit I'm a bit confused what the potentiometer actually is on this model. Are the sliding belts part of it? The Box which the drive shaft is connected to only? Do I just try get some contact cleaner in there or can I actually open them up? Should I be looking at all the electrolytics or just the big ones? (Or just the small ones?)
They are the long ones driven by the bands, sandwiched between the boards.
You cannot take them apart. The only way to clean them is to spray a good quality contact cleaner (I use Kontakt 60) down and then move the sliders back and forth a dozen times each.
Ideally all electrolytics. The larger ones will be the last suspects.
Thanks heaps, Ill get onto it
As my only real source of capacitors has quite a high shipping cost, should I be looking to replace anything else while im placing an order? Trimpots or anything?
I too, also aquired on of these beauties a few months ago, and after sorting out the lack of power (tiny spring broken in the power switch !), I connected it up and also got a lot of scatchy and random hissy sounds.  I decided to replace all the capacitors and found the big ones OK but nearly all the small ones were out of tolerance, many by as much as 100% !   When they were replaced it was a joy to hear, no more scratchy hissy noise, this just left the clutches to fix.
And here is my question (probably for Martin), I'm currently doing the volume, balance and tone control first, so I've dissasembled the cluth mechanism - do the components that make up the cluth assembly slide off the brass bar ? It seems that the "separators" are firmly glued in place, do they just need 'force' to remove them, or are they not meant to come off ? (obviously the cluthes are slipping and I need to replace/turn the rubber clutch plates).
Tim
Use "controlled force" to slide the parts off the hexagonal shaft.
