I too, also aquired on of these beauties a few months ago, and after sorting out the lack of power (tiny spring broken in the power switch !), I connected it up and also got a lot of scatchy and random hissy sounds. I decided to replace all the capacitors and found the big ones OK but nearly all the small ones were out of tolerance, many by as much as 100% ! When they were replaced it was a joy to hear, no more scratchy hissy noise, this just left the clutches to fix.
And here is my question (probably for Martin), I'm currently doing the volume, balance and tone control first, so I've dissasembled the cluth mechanism - do the components that make up the cluth assembly slide off the brass bar ? It seems that the "separators" are firmly glued in place, do they just need 'force' to remove them, or are they not meant to come off ? (obviously the cluthes are slipping and I need to replace/turn the rubber clutch plates).
Tim
