Beomaster 1000 model 2318 repair project
You need to add the photo under your profile first. Then when writing a post, you can press the film strip symbol - it will take you to your photos. Beware that it does not work in Safari but if you use Chrome there should be no problems.
Thanks for help
Thanks for help
Thanks for help
